Couple of questions on this engine. About how hot should the heads get while engine is at idle. Have heard that you should be able to hold your hand on it for so long, etc...I have a digital infrared thermometer on the way and am going to check it with that.
I may just replace the thermostats anyway as motor had been used in saltwater. Just doing some preventative maintenance to it before getting it out on the lake. Having a hard time locating thermostats for this engine, anyone have some ideas on that?
Last question is what are the compression specs for this engine? I did a compression check the wrong way the other day, engine had not been warmed up and throttle was at the start position. Compression was between 95-101 psi which averaged out to 98 psi. Am going to do the test the right way tomorrow and will post those results.
