slowboatin1980
- Apr 8, 2013
- 12
Sooooooo after replacing my first water pump and housing and seals and shifter linkage seals in my lower unit!!!!! I installed and there is water coming out from wheep hole awesome!!! but there is water coming out of behind big u shaped piece at the bottom by where the unit bolts up??????? Also this motor has been slow to rev and shakes alot at idle. Now when you are at wot it eventually planes out after like a minute and the rpm do go up but till then your a sittin duck.:dread: any help would help please lmao also new to this site thanks all awesome site though!!!!
