1998 johnson 200 venom two stroke.
the vro was disabled when i bought it and its been premixed.
Was running great and then started acting up no power/lurching etc so i figured carbs...
cleaned carbs and installed new needle and seats (oem) as the carbs/jets were relatively clean but the seats had a significant amount of black sludge on the rim that definitely would impede the needle/gas flow thru them.
Install them and it still wont run right without pushing choke. It starts right up, Choke it and it jumps up and screams..
The funny thing is that it will rev great at the ramp in neutral but the second u put it in gear and it has load it is boggy and no go until u hit choke.
I am thinking of getting a new ball and maybe there is a universal fuel pump out there that will work as a non vro pump since i am premixing. Any ideas?.. bad/clogged fuel pump...? I already put new plugs and fuel filter.
and FYI i consider myself pretty good when it comes to rebuilding the carbs, I have done it tons of times on different machines and know what im doing.
thanks!!
thanks!!
