seth3678pb
- Mar 27, 2013
- 2
i have a evinrude 18hp fastwin and i just recently replaced the damaged impeller and it still does not pump water out the back of the water i flushed out the system by spraying up the hose connecting pump to motor and it comes out of the hole it is suppose to so i need some help figuring out what i should do thank you god bless.
