Re: 1958 Evinrude 18 hp Fastwin
OK guys, new problem with the fastwin, and I need help. We serviced the basics of the engine (carb, water pump, lower unit oil, etc.) and ran it again today. Ran great for about 20 minutes until the engine acted like it jumped or slipped out of forward gear and revved violently. It sounded like it was cavatating (perhaps sucking air vs water) but it wasn't. The first thing we checked was the lower unit- it was completely fine. We even swapped it with a good one from my '61 Sea King just to be sure and got the same reaction from the motor. Also, I do not believe it is a worn or incorrectly adjusted shift linkage. The engine stays in gear, just doesn't allow the prop to react to increased RPMs. Here's my symptoms:
Ever since the high speed incident, the engine will not engage the prop past an idle speed. Its very strange. It will go into reverse, and stay in neutral as well as forward. However, as you try to rev the engine to WOT, the prop doesn't spin faster with the increased RPM's of the engine (the engine will continue to rev though). The prop only spins a little faster than at an idle speed. I feel like this is much more significant than a detent screw on the shift level by the cowling, but I'm not positive. Also, the teeth on the top of the crankshaft of the lower units do not look damaged whatsoever, which one would think would happen if it was slipping there. I'm lost. Any ideas? Thanks y'all.
