Grandpa Mike
- Mar 11, 2013
- 39
I have done my homework and read what "sticky's" I could find re: the cut-out switch. I'm somewhat disappointed that even on a general internet search, I can't find much on old outboard cut-out switch systems and operation.
Ours is a 1960 Evinrude Lark ll, 40 hp. On the port side of the engine is a device that is connected to crankcase pressure/vacuum (by a hose) in addition to a few wires. I did see that there are also connections to what appear to be mercury switches on the throttle linkage. I've figured out that the mercury switches are ensure the engine starts at a reasonable RPM. Their position, angle and connectivity to the throttle linkage makes that pretty obvious.
I have done what can be done, thoroughly....in the full restoration of the power-head and lower drive. Completely overhauled.
We've replaced what appear to be factory hoses, both fuel and water. New points, coils, condensers, plugs and plug wires. The carb was overhauled and kitted by me yesterday. New t-stat & fuel strainer.
What we are doing here is a full restoration right down to the graphics on the engine cover. In the interest of being thorough...I wanted to ensure that everything and anything that might cause a problem was new, repaired or replaced.
Synchronized the manual ignition advance, the whole enchilada. Honestly though, if I've found anything that is specific to marine outboards, I've asked. The cut-out switch is I suppose the last thing.
Can someone point me to a link or provide some info on it's operation and wiring. This thing is certainly not self-evident to an old-crusty auto mechanic like me.
Thanks a bunch! (picture to be attached as soon as I get one)
Mike
Mike
