phoenixgold2100
- Feb 3, 2013
- 154
I have a motor guide trolling motor 12/24 i would like to wire it for 24 only. I do not have a 3 wire plug it has what looks like a marinco 12/24 recepticle with 4 6 gauge wires going to it. two red two black. I have read I do not need 4 wires to run 24 volt so is it just a matter of disconnecting two at the plug and normal 24v wiring at the batteries? do I have to cut the white wire in the trolling motor harness that is supposed to go to 12v+? Or should it work if wired like this picture thanks
Just tried to wire it 24v and nothing........i took apart the plug and i have a black red and white wire inside.....but coming out of the recepticle i only have 6 gauge red and black
Figured it out guys.
