jason callahan
- Apr 6, 2013
- 1
can anyone help me on how to properly adjust my throttle/shift cables the control box has the nuetral throttle lever on the top it seems like there is a lot of play in both cables im having trouble getting it to rev all the way and engaging fully into reverse and after trying to adjust the cable its upset everything i no longer have nuetral throttle control and its throttling befor the shift cable even come close to engaging in reverse i have to manualy push the cable under the engine cover to get it to fully engage basically ive made it worse can it be adjusted or should i get new cables
