so I just got my 78 ssv-188 with a 150hp evinrude outboard so what is the best tech. to start for the first time for the season I put muffs on it and gas and all that good stuff I have worked with a 73 50hp but it wasn't so stubborn. I didn't change the plugs yet but I did get it to run so does anyone have any hints on starting I know every motor is different but and also I was reading the starting procedure on the engine under cover it states that on the warm idle lever there is a start setting so once I start it on there do I need to leave it there under warm or idle up then once ready to go to the notch below the start setting
