Re: 1983 Johnson 140 hp
If you have verified 100% you have spark and compression to support ignition and you know there is fuel, then the only thing missing is timing. But be very sure of all those things you THINK you have first. Don't assume anything without verification... Because you could be thinking you have those things and spend days scratching your head wondering what's wrong... YOu need four things for any engine to run, Fuel/Air, Compression, Spark, and Correct Timing... Leave any one of those things out and it will never run... So recheck each one again before marking it off your checklist...
