livinfulltilt
- May 1, 2012
- 73
Im currently working on a 1955 Johnson 25hp electric start (RDE-17 I believe?). I found a great video on youtube from a gentleman who shows how to fine tune the points on these motors (something he learned from here on iBoats). In his video, the flywheel has a marking for each piston that corresponds to the markings found on the magneto assembly (correct term?). Im sure many of you have seen this video, but in case you have not, he adjusts his points to open when each piston mark is between the two markings on the magneto assembly.
I am not sure if I am just missing something obvious here, but my flywheel does not have any markings to indicate piston position. I do have the twin markings on the magneto assembly, but that is all. Did I miss something obvious here? Or do I just set the points to .020 and reinstall the flywheel, double check points gap and nothing further?
I just installed new coils, and cleaned and transplanted a set of points and condensers from a donor. Figuring this out is literally the last thing on my list before reassembly and an attempt to start her up. Ive learned a great deal of maintenance and repair info from this forum and I appreciate the help you have all contributed from time to time!
Thanks in advance for the help on this!
