louisvillefisherman
- Oct 13, 2012
- 29
Re: 1988 Johnson 9.9 Carb issue.
Todays game plan:
Going to the local hardware store and buying clear tube to temporarily replace the line from pump to carb. Going to monitor the tube for fuel flow and possible bubbles. If I see bubbles then obviously I have an air leak into the line (which at this point I am praying for).
If that test passes (no bubbles) I will be unfortunately removing the carb and opening it up again. I would like to see if the little rubber idle tube inside the bowl is interfering with the float action. I made sure the dogleg was pointing in towards the nozzle well, but you nenver know once that thing gets sealed up maybe it moves under fuel pressure and obrstructs the float from falling back down and preventing it from leveraging the needle open.
But will go after the clear line first. I want to avoid popping that that carb off again if I can, I fear damaging that plastic top.
And again, thanks to yall for sticking with me. The confidence I have from this forum is so valuable. I would never have gotten this far with the iboats communitiy.
Todays game plan:
