Store Links Mobile - Shop Now
See more
See less
1958 Johnson 5.5 Mikuni fuel pump problems
  • 1958 Johnson 5.5 Mikuni fuel pump problems
    I have a 1958 Johnson 5.5 that I put a Mikuni pump #808492 on, and I am leaking fuel from the little copper colored disc on the top of the pump.
    1. Is there particular orientation that the pump is made to work in? Flat, sideways, etc...
    2. What is the little copper disc for?
    The pump can be seen here:
    808492 | eBay
    Re: 1958 Johnson 5.5 Mikuni fuel pump problems
    Is this a new conversion? Or have you used the motor with the pump?
    many men fish for years without ever knowing its not about catching one.
    • #3
      that disc is likely a smalll mesh to balance air pressure.... likely culprilt if leaking is a bad diaphram inside the pump
      • #4
        Click image for larger version
        heres a pic of a b&s pump mounted on a 7.5 johnson, the pulse line is obviously coming from a different location than it does on your 5.5, but for this pump, the top connector in the pic goes to the fuel in line, the bottom connector goes to the carb. if you are sure your lines are on right ( suck blow test), your problem could be as mentioned, a ruptured diaphragm.
        edit: the part # for the pump shown in the pic is 808656, so your lines may attach differently, but the suck blow test still applies.
        • #5
          The motor will run with this pump, but it is dripping gas through the copper colored disc. Stinks, because the pump should be brand new, off fleabay, so not worth returning.
          • #6
            If it runs it has a bad diaphragm.
            Chris
            Johnson - Evinrude Top Secret Files:
            Proudly Dedicating My Time To Antique And Vintage Style Outboards!
            • #7
              I will swap out to another pump. Thanks.
