phoenixgold2100
- Feb 3, 2013
- 154
I am getting constant alarm when key is turned on I have checked voltage on the over heat wire and I am getting 11 volts from it and when i hook up a test light to it Purple and tan the test light comes on so i have a ground in the tan wire I guess my question here is is there anyway to check to see if the sensors are grounded and how would i get them reset. the engine didn't over heat knowledge. I unplugged port side and the tan wire doesn't have ground anymore is the sensor bad?
Another question would jumping the purple wire to the s wire on a tach make the needle spike?
