I have acquired a Yachtwin 4 hp which I intend to get running and I think could be from the early 1970s serial number is 4036 E C 78082?
I am not familiar with the controls on this engine and have no manual or anything for it. what are the knobs on the front for? They both adjust from lean to rich (see attached photo) one high speed the other low speed, and how should they be set? They are both connected to the carb', the choke is self explanatory.
There's a lever on the side which I assume is the throttle because there's no twist grip on the tiller, it is marked "stop" "start" & "fast" but I can't see any way to disengage the drive or put it in neutral, because even in the stop position the prop shaft still turns when the starter pull chord is used.
