Hello..
I want to replace the old cable steering on my runabout with a set of Ultraflex PN M66X13 that I have taken off a same model donor boat.
However the 40 year old 40hp Evinrude has no method of attaching the end of the cable rod to the engine itself so it can swivel and steer
Has anyone got a good idea so I can make a fitting to bolt to the transom and then to the engine..? As the Evinrude needs to tilt when out of the water the fitting will have to move with the engine somehow when it is tilted.
Any help would be appreciated
Thanks Derek Alltree
