I just had my engine rebuilt from a blowout. Now the engine starts sometimes an fails to start most of the time. When the key is turned, the engine does not turn over, the starter just sits there and I hear what sounds like a click (spark) on the starter or the solenoid when I try to start. It's one click or a spark type of sound and that's it. The starter does not seem to engage.
The battery is new as of last year, but it was hooked up to the boat most of the winter while in the shop. The battery was fully charged when this happen yesterday, but I did not measure the voltage yet just to make sure. When the motor does start, it works like a charm and it seems to be on key when it allows me to start. For example, the beginning of the day, I can start the engine. I run it for some on the water, turn it off and fish. 20 minutes later, I try to start the engine and nothing. I have to fiddle with it for a hour and maybe it will start again. Rinse and repeat.
I was told this is likely the Solenoid going bad or a wiring issue. The boat is a 92 and the wiring is not that great. I'm going to clean all the terminals and see if I can get a good voltage reading of the battery and solenoid before anything. But, it's raining now, so I figured I would ask just in case to see anyone had any thoughts about this being a bad solenoid or something else.
