Here we go,
My boat was left outside one night and it got rained on. Since then my tilt trim hasn't worked. It worked perfectly fine before and I've run down all the possibilities that I knew to check. Here's the problem....running from the boxes with the relays to the tilt trim motor when i press the tilt trim switch, i have 12 volts as long as the wires running to the tilt trim motor isn't attached. When the wires to the tilt trim are attached i have nothing. But i can take the wires from the tilt trim and place them directly to the battery and the tilt trim motor works.
Any ideas or thoughts would be helpful
-Sam
-Sam
