espdeepblu
- Mar 29, 2013
- 7
Been looking for answers and a pile of new parts hasn't helped yet. So I turn to all of you for some further advice, I'm out of bullets.
The Problem: At low to mid throttle, the engine runs great. Fires up every time, doesn't misfire, skip, or anything else that might lead one to believe there is a mechanical problem with the engine. But as the throttle is slowly increased, at about 60% the engine acts as if it is losing fuel. That is, the rpms slow down and unless the throttle is reduced, the engine will stall. IF, the primer bulb is pumped while the boat is underway at the higher throttle condition, the rpms will pick back up and the boat will remain running, but eventually it returns to the "starved" condition and it has to be pumped by hand again to restore the power.
We've tried all kinds of troubleshooting to identify the problem with no luck. Here is a list of things we have replaced: the fuel lines, the fuel/water separator, the fuel filter, the VRO fuel pump, the primer bulb, rebuilt all 6 carburators, changed all 6 plugs and wires, the throttle and shift cables, the water pump, and the radio (not that we think that one would help).
What I'm looking for is some ideas on what we might try next. Its frustrating that it only occurs at 30 MPH and higher and operates so well in the driveway and at low rpms.
Any insight someone might offer would be greatly appreciated.
Graham
Graham
