Hey Folks,
I've got a 98 Johnson 50 J50TSLECC. When I got it it would not go into reverse. Started trouble shooting and I found bad shifting and throttle cables, replaced both with Teleflex Extremes. Removed lower unit and replaced seals. Checked clutch dog: all edges are sharp and square, removed pin spring and the 3 ball bearings. Cleaned the shifting plunger put ball bearings back with spring and put the pin back in. Put lower unit back together, filled up with gear oil, came across a new shift rod for a couple bucks, so I replaced the shift rod. Adjusted and triple checked shift rod height of 21 15/16". Installed lower unit. Of course this was done with unit in neutral. Checked the shift linkage and found one of the plastic bushings/guides was slipped out on the shift rod side. Put the guide back in. loosened the shifting lobe that rides accross the small ball bearing which indicates being in neutral by being in the center indention. Attached shift rod to linkage and made sure shifting lobe was still in the neutral position. Tightened this shifting lobe. Placed control box in neutral, adjusted shifting cable to fit snug with no slack while in neutral. Success, or so I thought. I was able to shift the unit into revearse-neutral-forward while turning the prop.
Filled up barrel of water and cranked the motor. Motor runs good, shifted into forward. Lower unit engaged and ran fine. shifted to neutral and the back to reverse, motor still running good and lower unit engaged and ran in reverse. Stopped the motor and went inside to celebrate. Came back out to finish up other minor work and started engine back up. Shifted into forward and began hearing "clunking noises" indicating the clutch dog was not engaging all the way. Put in neutral and clunking noise stopped. Put into reverse and "clunking noises" started again.
Is it possible that the shift rod lever should be slightly different than 21 15/16" due to wear ect on other parts?
Any ideas would be appreciated. I'm not experience and have never done this before. I do have a service manuel and consider myself to be pretty mechanically inclined, but I'm sure its something simple so don't hessitate to throw some insulting ideas or questions.
