Hi everyone,
This is my first project motor im taking on. I has good compression, 120 lbs both cylinders. cleaned the carb, new spark plugs and wires. I managed to strip the threads on the head (spark plug) and got them fixed. when i took the head off, the two coils were melted to the head, so i had to pry them off with a screwdriver. now that i have reattached the fixed head i cannot remember how the wires go back to hook up the coils. one coil has a positive ran to a 3 wire quick disconnect and the other wire is grounded. however the other coil has a negative grounded and a positive that has the same connector on it as the ground, as if it were supposed to be grounded or something. I cannot get a spark so i am not sure if i just flat out do not have it hooked up right or if it is something in before the coils in the ignition system. Any help or suggestions would be awesome! im not against replacing the coils, i would just like to know how to hook them back up! thanks
Eddie
Eddie
