hanks in advance for your responce.just decarbed j140tlcte and noticed a small stream of water comming from exhaust to cylinder head gasket i have new one, will atempt to install should i use some type of sealant and i would appreicate any questions or advice you would give as im new at this ,i need a service manual the only one that might be good ive found is pretty pricey.thank you guys for your time and advice.
