Im working on a 1930-32 johnson a-50 4hp outboard. The condition overall is pretty good! Some questions I have about it are if it is water-cooled, if so, where would the water pump be located? Are the low and high speed adjustment needles set the same as the 50's and up motors or is it different than 1 and 1.5 turns? Anything helps. Thanks!
