My '91 V4 120 Evinrude has been a sweet engine for over 20 years- extremely reliable with proper care, until now. Symptoms- was running well, close to WOT then stopped (no stumbling/sputtering like loss of fuel). It died like turning the key off. Started again, ran, and did same thing and then would not start at all.
Fresh tune up on engine- carbs rebuilt, fuel cell removed, drained, 100% fresh new gas.
Once back at home on garden hose, I find the problem is intermittent- sometimes will start and run for 1-3 minutes. I attached a timing light to watch firing to individual cylinders. When it will not start, none of the 4 plug wires have firing. When it does start, all 4 fire, then become erratic firing, and stops. Wiring system is immaculate- no weathering, rubbed spots that can be located, and all plugs and terminal strip connections have been checked for looseness and corrosion, etc. My thinking is taking me to the CDI unit. Anyone have experience with any testing on these before I start swapping parts?
Many thanks
Reno
Many thanks
Reno
