Hi all, thanks for a great site.
I've just bought a boat with a electromatic 80hp V4 Johnson which I have decided to clean up and rewire. The hydraulic tilt motor is gone and was barely working so I decided to take it off and want to replace the lines and the unit. The one in questions is attached as a picture. The date stamp is 09 68 or something so I assume it's a '68 model unit and another marking says 104183.
Does anyone know of an aftermarket unit suitable as replacement on ebay? It is a 3 wire and 3 pipe unit with pump/motor assembly.
Thanks,
Regards,
Craig.
Thanks,
Regards,
Craig.
