i just purchased a boat with a 1994 Evinrude 30 E30ELERM, was told motor ran great. i put on the muff type motor flusher attached the hose and turned on the water. the motor fired right up and i had it in fast idol but i did not see anywhere that water should be coming out. unless the exit is in the area of the prop. can someone tell me where the water flow exit is located? is there any reason i would not be getting water flowing out?
also, what is the desired oil-gas ratio for a motor of this size and age?
thanks
thanks
