69 evinrude 4hp folder. won't pump water or very litttle. checked impeller and sealed pump housing. water tubes in place. compressed air thru upper tube and comes out exhaust housing under power head. very little salt in eng. removed head and ran eng in tank spinning with drill. no water coming out port hole in block. put head back on, fired it up and checked head temp. quickly went to 200+ degrees. pulled head and only damp in block. gromets in place between the folding units. impeller in good shape. any thoughts?
