Decided to post new thread since I listed it as a 1958 on the old one. The new wiring from control panel (start/stop) to the solenoid to engine is coming along. If I can't get a harness from the solenoid that plugs into the engine then I'm just going to bypass the connector and just wire straight to the components. Maybe able to rig a different connector, anyway I checked the compression and am getting 80 psi on both cylinders. Probably not as high as it maybe could be but at least they are the same. Removed the lower unit drain plug and about a teaspoon of clear water came out and nothing else. The oil is in there just gummed up from sitting for 7-8 years. Prop turns fine in fwd and reverse, no problems. Any ideas on this would be greatly appreciated.
