Kiwifisher
- Feb 24, 2008
- 58
I have a very annoying problem on my 2001 90 hp Johnson v4 looper. Motor starts an runs fine when boat is on trailer with water connected to flush muffs. When I put the boat in the water, engine starts and runs fine but after a short while I notice the 4 warning lights flash as if doing a power on test and the audible alarm beeps. This may happen 2 -3 times. The engine still runs fine. Then suddenly the warning lights would flash in sequence again and the rev counter will stop working.
The engine will continue to run but trim/tilt won't work and if I turn the key off, the motor won't fire due to a blown fuse. Once I take the boat out the water and replace the fuse everything works fine until the next time I put her back in the water.
Has anybody got any ideas where to start looking for the electrical problem that's causing this? I'm getting desperate at the moment!
