Re: 1985 90 hp evinrude fuel problem
Sounds like the engine runs fine, except at idle. Likely a fuel/carb issue. When that engine idles, the carb butterflys are completely closed. The fuel supply at idle goes through very small (dedicated) idle passages in the carbs. These tend to get blocked/restricted by dried fuel over the years. Once these get restricted, the engine just won't idle right. As soon as you crack the throttle, even a little, other jets will supply fuel and the engine may run just fine. Some carb cleanings won't handle the dried fuel (gel) from inside these hidden passages. Sounds like you need to pull the carbs down again, and spray an aerosol carb cleaner (like a Gumout type product) through the idle passages-then reassemble. You'll want to spray one passage on one carb, noting the exiting spray pattern. Then pick up carb #2 and do the same passage, noting the exiting spray pattern. Both should have the same exiting spray pattern. Then go on to the next passage on carb #1, etc, etc.
