I have 6 injectors from a parts engine that I need to know the injector parameters to program an EMM.
These injectors are off a 2000 225 Ficht. They have a barcode on them that appears to be only the serial number encoded on the bar code. They DO NOT have the square QR code on the side of the injector.
If I have the serial numbers of the injector, can I get the injector parameters from Evinrude?
The reason I ask here, is that I called an Evinrude dealer in Orlando, and they said I had to buy new injectors in order to BE SURE I had the proper parameters.
I will call Evinrude customer service, but I was wondering from you pros that are Evinrude authorized whether you can actually provide the serial number, and get the parameters.
Thanks!
Thanks!
