Hi to all I-boat experts
I have a 1979 Johnson 9.9 model 10R79B. I am currently in the process of removing the powerhead to replace a upper water tube grommet. I think I have removed everything to get the powerhead off but the throttle side of the motor is confusing me. When the powerhead comes out does the vertical control shaft on the throttle side slide up and out at the same time or is there something I should be disconnecting there also? I would rather ask you folks before I try myself. I have a manual (clymer) but it doesn't say anything about it. Also if anyone has tips to removing the powerhead if the gasket is stuck I sure would appreciate it. I do have all six lower and three upper bolts also removed. Thanks for all your help.
