Recently acquired 1957 3hp Lightwin. Model 3022 for $40.
Seller said it was his Dad's motor and he could remember going out with it as a kid. Said it worked fine. When asked how long it had been sitting he guessed that it has not been in use for at least 30 years.
I suspect that he tried to take it apart to see what was wrong with it because all of the nuts and screws came out easily. Many by hand. Even the flywheel nut and flywheel opened up easily.
I intend to follow the procedure here: Outboard Boat Motor Repair and Tune-Up old Evinrude Johnson
for replacing coils, water pump impeller, and carb rebuild.
I know that I need the manual and would like to order with the parts.
In addition to the parts listed in the above link, I can tell that I should get:
300565 Propeller Clutch ring. What is procedure for replacing this? (Currently dry and cracked inside of propeller)
Propeller shaft cap looks OK. The nut is inside of the conical shaft cap but seems loose... Does it just sit inside of this cone?
There is no cotter pin. The hole in the shaft is full of rust, so I'm guessing that the pin rusted and sheared off when Previous Owner tried to take apart.
The in-tank fuel filter is completely disintegrated. The adapter is wrong and has been cobbled together to allow for non-standard fuel shut off valve. Tank appears to be sound but needs cleaning. Unplugged vent hole in cap.
Need: Fuel Shut off valve, Adapter to tank, flex fuel hose, Chain to keep cap from falling overboard, inline filter, clamps.
I can also see that at least one of the spark plug wires is pulled out from attachment to coil. Coils are in bad shape but planning on replacing. How do the wires attach to the coils? What kind of wire (I've read solid core) do I need? Where to get it? What Length?
I also need pull handle. Cord looks OK. I'll probably buy whole assembly, change handle and keep rope as spare.
Anything else that I should be getting.
I'll try to document process and keep advised of progress. In the end, I'm guessing that this 56 year old motor will work great with my 42 year old Sportspal canoe.
Thanks in advance.
Thanks in advance.
