emerson281
- Feb 17, 2013
- 7
Evinrude 40HP big Twin Model # 40652B
6 Gallon Attwood gas tank
I got this motor professionally tuned about 2 years ago. I can't find the receipt, so I'm not sure exactly what all was does, but I seem to recall some carburetor work (probably a rebuild) and possibly a fuel pump. Both the carb and the pump look brand new. For what it's worth, they (carb and pump) are spotless...they look extremely clean on the exterior. It ran excellent after that tuneup for about 1-1/2 years, then it started acting up.
Problem: It dies when you give it throttle. It starts fine. It idles O.K (both in and out of gear), but as soon as you give it gas, it stalls...even in neutral. Again: It stalls when giving it gas both in gear and out of gear.
History: On a trip a couple of months ago, the motor started fine, idled really nice, putt-putted nicely out of the marina and accelerated fine. It ran at full throttle for about a mile and then began to slow down (lose power) as if I were backing off the throttle. I checked gas tank fuel lines and fiddled with the gas cap...the relief valve on the gas cap was screwed on tight. I loosened it, pumped the bulb and got underway for a full afternoon of stop an go fishing all up and down the river.
Next trip: I made sure the gas cap relief valve was loose (as it should be). Same thing happened (starts, idles, putt-putts, runs for a short period wide open, then loses power). I pumped the bulb, removed and reinstalled the gas tank fuel lines (at the tank and at the engine). This time, I loosened the whole gas cap (not just the relief valve). I started it back up and all was fine for the rest of the day. In fact...the motor sounded and ran great.
Next trip: Before I went, I bought and installed a new gas cap. Same problem. Went through the bulb pumping, fuel line routine again, making sure the relief valve was open (it was), loosening the gas cap, and soon we were are on our way again for another full day of normal usage. The motor sounded and ran great
Next trip: Bought a new tank. Same thing happened again...except this time I could tell at idle that something was wrong as soon as I drove it off the trailer. I cleared the marina, accelerated...and stalled. Went through the whole bulb pump/fuel line routine and got nowhere with it. I had my brother pump the bulb while I tried to accelerate and it just kept stalling out. I ran home, grabbed the old gas tank, put it back in...no joy there either. Ran to the store, bought a whole new hose/bulb assembly...no joy. Got it back home, hooked the water hose up to it , started it and shot some carb cleaner into the carb...same thing...stalls when giving it gas.
When it stalls out after giving it throttle, it definately doens't sound, smell, or look like it is flooding...it seems the opposite..like it's starving for gas.
I can't afford another couple of hundred in labor for this motor. I'm going to have to take a shot at rebuilding the carb and possibly the fuel pump. I'm a little apprehensive about doing so because I've only installed a carb kit a couple of times before: a lawn mower and a generator. I can't seem to find a definitive answer on which fuel pump goes on this motor and if a rebuild kit is available for that fuel pump. I'm concerned as to whether or not the last tune-up I got for it included a new pump, and whether or not it was the right pump.
Does anyone have anything else that I should check prior to tearing down this carb? Is there some other little trick that somebody knows that can help me diagnose this issue. I really want to make sure that I've covered all my bases before I tear into that carb.
Thanks,
Shane
Thanks,
Shane
