i have a 2003 90HP Johnson outboard. I was wondering about the cooling system and the "P"stream I should see when the engine is running. There are 2 ports on the back of the engine, one is plugged and the other is open. It blows out air when the engine is running. Shouldn't there be a visible stream of water somewhere to assure water pump/impeller are working? i see nothing. The engine runs great and ive had it out a few times but every outboard i have ever seen has a visible stream of water... Thanks
