sixsicsix19
- Jul 16, 2012
- 13
When testing the motor in bucket i noticed it was not pumping water out so i took lower unit apart to check impeller and it was in pieces. But before that i was gonna drain all the oil out the lower unit and no oil came out just alittle water! What can i do to see if the lower unit has allready been damaged from no oil or if its ok? i dont wanna spend alot of money on all the parts for the tune up to find out the lower unit is screwed up.
