Re: 73 135hp evinrude solenoid help
It has to be cranking a minimum of 200 RPM to have spark. Try it with the spark plugs removed (it will crank faster without compression). If it then has spark, it is either cranking too slowly, OR the stator under the flywheel is bad. Most 1973 stators went bad so it may have already been replaced. Look for goo running down from it.
If none of the above, other possibilities are bad power pack, or bad timer base, or bad coils. Proper troubleshooting is in order with a DVA meter, or start replacing expensive parts that may not be bad.
