Re: 35hp johnson solenoid clicking
Yes, a single jumper cable to the starter should spin it.
The "majority" of starter problems are also caused by corrosion on the connections and inside the main leads. Corrosion will rob your system of power by raising the resistance in the wiring. Annually I strip all of my electrical connections and sand them off and re-attach them.
