Re: Trying to locate '94 evinrude 140 vacuum leak
Consider.....the tiny holes I refer to allow idle fuel to pass to the cylinders thru the side of the throttle bore.
If those are clogged partially, the fuel/air mix getting thru would be very lean, right?
So, on your particular motor (you have that oddball carb design), the idle mixture screw adjusts AIR, not gas flow. When you turn the screws in, you are shutting off AIR, and that would richen up an already lean mixture.
You did say it ran better with the idle needles all the way closed, right?
Make absolutely sure the idle pickup tubes in the carbs are open. Those are the brass tubes that extend into the bowl.
They are not the same diameter throughout their length. They get small up at the top where they press into the plastic carb body.
And you know that the top of the tube opens into the labyrinth air/fuel flow passage on the stbd side of the carb that is covered by a metal plate. I have seen idle circuits clogged at the top of the brass tube. It doesn't help to blow air thru there, it is best, believe it or not, to suck on that brass tube and feel the flow of air on your tongue. You can really judge from carb to carb if they are the same, or if one is clogged.
I kid you not. Tastes bad, but only while you have the tube in your mouth.
