dkonrai
- May 9, 2009
- 719
i was given this motor, and just wanted to share this. it sat for 25 - 30 years in a shed. brought her home, pulled the plugs and shot a little 2 stroke oil. sprayed some seafoam down the carb. gave it a few turns rolling her around for a couple of days.
finally had some time to give it a run. couldnt get it started, so i used the drill method . (i know its not good, but it works when your old).
i am amazed that a motor can sit for so long and still run pretty well. compression before i ran the motor was 72/72. will run some sea foam for a decarb. also some points/cond/coils/impeller will be installed as well
here she is
dont know if the video will come out
here she is
