midsized johnson
- Jul 28, 2005
- 155
In another thread I asked about getting the "no oil" light and buzzer to shut off. I believe I've successfully done that. However, in checking to see if the overheat buzzer will go off if the motor gets hot, I can't get the buzzer to sound. I tried grounding both sensors individually from the harness side (tan wire) with the key on. The buzzer is new and sounds everytime the key is turned on.
My question is where to start the check? Is the problem more likely to be in the wire loom somewhere or maybe in the system check gauge I just bought?
Thanks in advance for any input.
