I have a 1979 Johnson; 70EL79 that uses the primer bulb tanks. We want to use two fixed-mounted tanks that both tanks and would like to have them both running to the single fuel feed so it can pull at the same rate. We want one of the tanks to have a sending unit to the dash. By using both tanks feeding at the same rate, it allows the boat to maintain balance. do I need to use an external fuel pump in addition to what the motor is pumping and remove the primer?
