Hi folks,
I ran my 86 28 SPL till it was dead, and just picked up a 79 'Rude 35 horse to replace it.
I am trying to use the same control box from the 1986 motor, which was a one lever box.
Took it to the river today, and it had a little trouble shifting between reverse, neutral and forward. It seems almost as if the range of the control cable is not enough to hit the right spot to get it into forward when its in neutral. Sorta like the area that comprises neutral is way larger than it was on the 28.
In doing a little research on the cables, it seems there was a change in the cables around that time. SO, my question is, am I definitivly trying to use the wrong box/cables, or is there more likely some difficulty with the lower end?
Thanks
Thanks
