JaSla74
- Oct 14, 2008
- 506
Hey Guys,
I have a 71 18102s Evinrude. I've been freshening her up a bit, changing points, rebuilding carb, etc. I noticed the powerhead gasket was leaking so I pulled the head to replace & wouldn't you know there are two other gaskets that need replacing. Problem is they're are obsolete.
1st is 313565 GASKET, Inner hsg #112
2nd is 0308292 SEAL,Housing cover #35
I've googled & searched the site a bit, but answers vary. Crowleymarine provided a few contacts, but if a man wanted to make one himself what would you guys suggest? Would RVT suit my needs here? Thanks
