CaneCutter79
- May 24, 2009
- 454
I have to pull my carrier bearing assembly to replace the bearing seal (part 0382408) for a 1979 85hp Evinrude (mo. 89995R).
I was told there is a special OMC tool that is basically a big long rod with fine threads on the end. I was told I could make one but I'm not sure what diameter the bolt is or the thread. I just assume buyt the tool and be done with it.
Can anyone help me find this tool? I was told I need to back one of the bolts completely out, then insert the tool to keep the backing plate in place when the other 3 bolts are removed. That way, when I remove the housing, it doesn't come apart or loose it's reference. Seems like a cool trick.
