looking at a used jet drive which has been converted with a standard gear case. before I do a reman powerhead.
the model number is J90JLERC which shows a 94 90hp
the motor cover says 65hp. were these motors rated diffferently because of the jet drive?
anything different beside the lower unit?
is 140 psi good compression for this motor?
