Hi Guys,
I have a 1975 Johnson 50 HP outboard that is stuck in forward. It happen when we were on our last fishing trip.
I have changed the oil with a type "c" gear oil.
I have also tested the wiring from the knife connectors and the green wire is open circuit. The blue wire is 5 ohms.
My questions is their any other connection or terminals between the knife connectors and the solenoids or has the forward solenoid gone bad.
also does anyone have a manual for the lower unit and leg so we can remove the lower unit if needed.
Thanks in advance for your help.
