classiccat
"Captain" + Starmada Splash Of The Year 2020
- Dec 20, 2010
- 3,405
I'm rebuilding the LU of my 35ELCTS after seeing alot of metal shavings in the oil.
After breaking it down, I was greeted with the following:
The last person to have operated on this LU was an Evinrude dealer 4-seasons ago
2 observations:
Questions:
Damaged Cradle (clutch dog, reverse gear & prop shaft were as clean as a whistle)
Pinion:
Forward Gear Damaged (2 teeth):
Housing Gouged:
Thanks!
- Pinion Destroyed (must replace)
- Forward Gear Damage to 2 teeth (plan to replace)
- Shift lever Cradle is lightly gouged but I think i can file out the defects
- LU housing: Deep gouge that I can repair
- Clutch Dog, prop shaft, reverse gear and bearings were all in good shape.
2 observations:
- there weren't any shims found (nor does it say to shim these gears in the Seloc manual)
- the front bearing race fell-out when I tipped the housing
Questions:
- Does this model engine require shims?
- Shouldn't that race be pressed-in? I was quite surprised when it fell-out without any "persuasion"; I believe this to be root-cause.
Pinion:
Housing Gouged:
Thanks!
