Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Impeller Rotation DIrection Significance?
  • Impeller Rotation DIrection Significance?
    I recently changed my impeller, on my small 9.9 johnson 1977 outboard, and was wondering does it really matter which direction the impeller is positioned in? I put vaseline around the edges of the veins of the impeller, so wouldn't the impeller direct itself in the direction neccasery when I run the motor?
    Re: Impeller Rotation DIrection Significance?
    If you're lucky it will. Run it wot and if it doesn't overheat you're okay.
    • #3
      Most of the time they will set themselves but not always, If you do run it wot, do so in forward gear on the back of a boat, not in a barrel and never in neutral ..
      • #4
        The repair manual for my motor indicates that, when installing a new impeller, the vanes should be greased and the housing should be installed while rotating the drive shaft clockwise. That takes care of the proper orientation. Running it in may not cause a problem, if done as suggested in previous posts. But, why take a chance?
        • #5
          Im pretty new to boating, and engines but whats running it "wot"?
          • #6
            wide open throttle.
            and as mentioned don't do that in neutral, only in gear while underway.
            Checkmate Rebuild: http://forums.iboats.com/forum/boat-...eckmate-eluder
            “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
            ― Isaac Asimov
            • #7
              Ahh Thanks! I thought you guys were intentionally mispelling "hot" or "wet"...I know im a bonehead sometimes
              • #8
                trying to gain information & knowledge, is a far cry from being a bonehead,, the good news is you came to a wealth of both here on iboats there are some on this site who are absolutely amazing in their skill level, knowledge of outboards, historical information, and many other special marine/outboard related talents.
                • #9
                  Agreed.....To the poster, check out this thread as proof of the above statement! Amazing how fast info gets out there---EVEN ON A 1915 MOTOR!!!
                  • #10
                    Im still completely amazed at the expertise and swiftness of responses to my questions, Im extremely lucky to have found this forum, and thankful to the majorly informative forum posters
                    • #11
                      My 9.9-35 hp manual says "...install the impeller into the impeller cup. Sharp edge of cam slot is leading edge during rotation." This should give the drive shaft a more secure bite on the impeller with that sharper wedge leading.
                      • #12
                        Ok I changed the impeller, did all the work vaseline and all, placed the lower unit back and put it on my boat. I just put it in there without calculatin which way it should spin, clockwise or counter and the thing pees like a race horse.
                        • #13
                          Go buy a Lotto ticket. LOL
