Hi all, Due to a gearbox issue (shift collar jumping), I pulled my lower unit and bolted up a good second hand one. It selects gears fine, and turns the drive shaft, however the pump does not pump any water out the pee hole. water isn't even getting as high as the powerhead.
the waterpump on the new (second hand) lower unit was supposed to be brand new, but I pulled the lower unit again, and put the water pump and impellor from the old lower unit (it pumped water on saturday), and tried again. Still isn't pumping water to the powerhead.
It feels like it is sucking water in through the water intake screens if i put my hand near the (I am running it in a test tank, with water over the anti-cav plate). but it is not making it to the powerhead.
Any ideas where to start troubleshooting? I have changed the impellor before in the past, and never had an issue like this.
